anybody know the door jamb axle code for a 4.10
jsomedaysoon
outer banks nc
i thought i've seen it in an old thread but i just did the search and couldnt find it. I'm going to a junk yard wednesday to try to find some axles with the 4.10 gears with a limited slip in it. Anybody know the door jamb code for that. Or the actual axle tag code even though those are usually hard to read. Also what other trucks have axles that would work in the bronco?
I believe the axle code for 4.10 gears with rear L/S is "H5", and you'll often see it as "H52" with front & rear L/S. that will be in the F-150 series trucks.
Virgil3rd
