yo 96,
Push Button Switch
w/very basic installation info.
Fancy System @
https://www.digitalguarddawg.com/auto/
But Big $$$
Actuator Rod Pics (Upper & Lower); 92-96 w/Ford Part Numbers by
http://www.steeringcolumnservices.com/ford/ignition-actuators.php
"Actuator (upper)
This white plastic ignition actuator gear with teeth often breaks prevents you from starting or shutting off the vehicle with the ignition key. The ignition rack actuator failure if often misdiagnosed as a ignition lock or ignition switch problem.
Actuator (lower) OEM # F2DZ 3E723 A
Fits Makes: Ford Cars & Trucks
Fits Years: 1992-2008
$28.63
This white plastic ignition actuator is the lower actuator on most Ford cars and trucks. This piece is actually what joins with the ignition switch to start the car. It is pushed by the ignition lock cyliner and upper rack gear.
Our Part # RACK06
OEM # F0DZ 3E715 A
$32.08"
Actuator Replacement w/Tilt; "...Symptoms of the problem before tearing into the steering column was that I could start the truck, but not shut it off. The key was easily turned without any “normal” resistance/spring to it and all accessories had power with the key in any position. The rest is pretty simple though. All reverse of installation..."
Source: by KC200787 at
http://fullsizebronco.com/forum/showthread.php?t=181708
ASAP, find out if speed control recall work, if equipped was completed. If you still have concerns about Recalls, please contact the Ford Customer Relationship Center:
US: 800-392-3673 | CA: 800-565-3673
Note: 3673 spells "FORD" on phone keys
For the hearing- or speech-impaired: Please contact the Telecommunication Relay Service by dialing 71
... have VIN ready.
"Summary: ON CERTAIN PICKUP TRUCKS, PASSENGER VEHICLES, SPORT UTILITY VEHICLES, AND MOTOR HOMES CHASSIS, THE SPEED CONTROL DEACTIVATION SWITCH MAY, UNDER CERTAIN CONDITIONS, LEAK INTERNALLY AND
THEN OVERHEAT, SMOKE, OR BURN. THIS COULD RESULT IN AN UNDERHOOD FIRE."
To confirm current status, use this guide by jowens1126 @
93 & 94-96 Cruise Control Recalls Repair
Note that the 93 recall is different than the 94-96 recall.
Here's the
1996 Bronco/F-Series Workshop Manual partial
Download it.
96 Bronco Owner's Guide, Maintenance Schedules & Parts and Accessories by Ford @
Owner Manuals | fleet.ford.com
96 Bronco Dealer Brochure @
1996 Ford Bronco Technical Info pictures, videos, and sounds | SuperMotors.net ... scroll down
96 Bronco Quick Tips Brochure Excerpts & some Eddie Bauer options @
1983 Ford Bronco 96 EB Bronco Brochures pictures, videos, and sounds | SuperMotors.net
