'94 bronco
hockeyfreak55
georgia
I'm 17 and just getting into off roading any tips will help, but most of all i need to know abount my motor;
i got a 1994 bronco with a stock 5.0L (302 ci) engine, 185 hp @ 3800 rpm 270 ft/lb @ 2400 rpm. and a 2 in lift. how well will it do at mudding in georgia, mostly along the alabama line in/around douglasville?
Jeep'nBronco
I run a 84 and with 32s without a lift it conquered alot of thick clay here in utah. It all mainly depends on gears, axle strength, lockers, diff and frame clearence, tire size and how well it grips and cleans. deffinently need to seal off the distributor and if water is envolved then maybe even a snorkel.
needatruck
Im from outside of huntsville and the terrain can get rough around there, if you got boggers or something along that you should be alright but if you get to somewere where you have to flex out, try and stay away from that cause with the 3'' you got isent very high and you will sink your tire up in your fenderwell, and **** your tread up, but other than that you'll be alright.
