grumpy old man
Just found an 89 Bronco II Eddie Bauer for my granddaughter. Bought it cheap enough that I can afford to fix it RIGHT. It has been sitting for a loooooong time and as a result it only has 68000 miles on the clock. Will start on starting fluid and will idle about 300 rpm, touch the throttle and it dies. I am guessing that the injectors are plugged from sitting for only God knows how many years. Ordered a new set and will find out if I am right when they come.
My current problem is the front brakes, wheel bearings and automatic hubs. I plan to rebuild or replace everything in the brake system. rebuild calipers, replace pads clean out all the old grease and repack everything with Lubrication Engineers. drain and refill both axles, the shotgun approach just do it all.
My question is the front hubs and auto locks. I have never seen them, I got out of the business 20 years before this was built And I know nothing about it. I really don't want to go in with guns blazing poking prodding and hammering to get it apart and wind up ruining something that is probably expensive.
Is there a publication somewhere that I can get for reference, or some other source of information.
Thanks in advance for any information you can offer,
Dwight
Dwight
