85 b2 2.8 backfires and dies.
crustyjuggler27
i have an 85 b2 v6 5spd, some times while driving the "EMIS" light will come on and it seems to act like i took my foot off the pedal and bog down. then it pops extremely loud like a gun and drives fine. and other times it will do that when i take off from a stop and die on me in an intersection. it scares me so much that i wait for a huge gap in traffic to take off. any help would be appreciated. ty Chuck
BroncoJoe19
I'd start with a good tuneup, and check for vacuum leaks.
If that doesn't clear it, then I'd pull diagnostic trouble codes.
Pull Diagnostic Trouble Codes (DTCs) From your onboard computer.
Your engine and transmission are computer controlled.
The computer uses sensors to tell it a number of different things and it controls actuators that push or pull mechanical levers (kinda). If one or more sensors aren't working properly, the computer goes "blind" and doesn't know what to do. If the computer can "see" but one of the actuators is broken and therefore can't follow the commands of the computer; the engine won't run correctly. The computer is preprogrammed with set values for each of its sensors, and each of its actuators. It will run a self check of all systems, like the space shuttle; it will compare its set value(s) to the value(s) it recieves from its sensors, and actuators. If any sensor or acutator is out of the "normal" range the computer will generate a "code." It will generate some codes on the fly, and others will be stored while you are driving. There is a simple method to "pull codes" out of the computer for one to use for diagnostic purposes.
Earlier versions of On Board Diagnostics OBD 1983-1995 can flash the error code to the dash board and can be pulled in one's driveway without any special tools.
Later versions of On Board Diagnostics OBDII some 1995, and pretty much all 1996 and newer, require one to use a code reader or scanner tool.
Some auto parts stores will scan your engine codes for FREE, you may want to call around. Some will scan OBDII but not the older (prior to 1996) OBD systems.
SO here you go...
How to scan FORD on board Diagnostic Trouble Codes (DTCs) in your driveway
Howto Pull Codes 1983-1995 Broncos, Mustang, F series Trucks, Econolines, 302, 351 and more
C
crustyjuggler27
super helpful. i did a tuneup but havent gotten to the fuel filter yet. i havent noticed any vacuum leaks but i'll check again. then ill post the codes if they come up thanks again
digs
