About all the two engines have in common is 351
/emoticons/smile@2x.png 2x" width="20" height="20" /> . There are very few interchangable parts, infact next to none. They both get their name from the plant in which they were manufactured. Clevelands were only built from 70 - 74 so there are not as many available as Windsors. The Cleveland has a lot of fans and it is said that if it's built correctly, it can produce plenty of power.
The bell housing on a Cleveland uses the big block 5 bolt pattern so you will have to change the bell housing on the transmission. I'm not sure about engine mounts, but I would guess they are not the same. The 83 Bronc uses a Duraspark II ignition system and should pretty much drop in, or you could use a custom ignition system.
A lot of performance builders seem to like the 60s and early 70s engines when building a small block based engine. 351Ws from 1975 - 84 had a reputation for poor quality block casting with cracking problems and just plain crappy workmanship.
You canfind the actual year of the casting from the casting numbers; ex. D4AE - 6015 - A D = 1970-79, 0 =year 74, A = Ford line, E = Enginegroup, followed by basic part number, and revision level.
So yah, you will have a bit of modification, but since you have it on hand i'd go for it. I'm sure there is someone on the forum that has done it already and give you the conversion details.
