1988 to a carb
Jeff Ogden
Dayton Ohio
I am tired of dealing with replacement fuel pumps that wont last a year so its time to go to a carb,since I want to swap in a 351 I have found a complete low mile 4 bbl 1985 351 that will make the swap easier. The question I have is where on the EFI wiring harness can I find 12 volts for a duraspark ignition and what wire will I have to hook to the duraspark coil to make the tach work and is there anything else I should know when converting to a carb.
Hook it up like the attached diagram.
JLasvegas
Have you been running your tank to almost empty before filling up? If so that could be the cause for burning up fuel pumps
J
Jeff Ogden
Dayton Ohio
I do not let it get lower then 1/8,might convert it to the newer single pump system before I give up on the EFI but not real happy with the two pump system. I tried to find a 87 with a 351 so I would not have to bother with the EFI but could not find one around here that had a decent body.
