1975 rear axle
bigbluebronc
ca
How do I make my 1975 rear axle housing strait , the passenger side leaksno matter what I do and It wheels or has wheeled hard very hard the degree wheel says I am 3 degrees ofset one side too the other??? any help is great!!
Yardape
Alberta
I would think you are S.O.L. There is an article in this months four wheeler magazine (I think thats the one) About bent axles on a jeep d44, theres a kit you can buy to sleeve the axle tubes, but thats preventative not really a fix after the fact.
S_bolt19
Colorado
I'm with Yardape on this one. Besides, 9" housings are cheap to buy & they are easy to swap out. Pull the 3rd member & axles out of the housing & put them in a new one and be done with it. Shouldn't take more than an afternoon to swap out. You only have to disconnect the brakes, driveshaft & springs and that thing will come right out. It isn't like the front end. Once it is out, you should be able to transfer everything over in a minimal amount of time unless you swap your brakes with it.
