Back door window stuck
2good2be4gotten
Hello, Bronco fans.
I have a 1995 years full size Bronco and now I also have a problem. The window on the back door is stuck. The motor is running but the window won't move. Anyone got a clue what the problem might be and how to solve it?
Best ragards
2good2be4gotten
2good2be4gotten
If the motor is running but the window doesn't move, then you need to replace the gears on the motor. You can get a kit from the Bronco Graveyard, go down the page to Window motor repair kit http://broncograveyard.com/bronco/c-189.
Thanks for Your answer. I'll order the kit and go on with the replacement.
'...Always under restoration.' The road to success is always under restoration. ;-)
Best regards
Bo A
