91 ign. switch schematic?
WBKrazy
the hills of RI
okay here goes... i've got a 91 eddie b 5.0, the the actuator for the ign switch broke again, dont really feel like fixin it again or replacing the column cause the key lock still works, so ive got a pushbutton switch and some toggles, and im gonna rig em all up in the ashtray on a small board so i can hide them while it's parked.... does anyone have the schematic for the ign. switch?
I can appreciate that it may be a bit of a pain, but there are so many circuits that go through that switch, IMO it would be easier to replace it and fix it properly.
W
WBKrazy
the hills of RI
i know there's a lot o things runnin thru there, but there's only 8 (i think) wires that plug into the ign. switch... all i need to know is what ones are energized when you turn the key to acc., what ones are energized when you turn the key to on, and what ones energize the starter.. i have 2 toggles, one for acc. and one for on, as well as a pushbutton for the starter.. just need to know what wires do what.... i'm sure someone on here has done it before...
Its only a $12 part. Don't you have to pull it to get access to the wires anyway?
I have pinouts for a '96 model, and its different. Haynes and I am sure Chilton's would have the pinouts for you.
