Turn signals
Seth
Replaced the flashers and the hazards, headlights and rear lights work but my turn signals aren't.
What do I do? And the metal piece within the signal switch, if that's not positioned right can that cause them not to light up?
(Picture - It after you remove the circled *****)
S
Seth
Yes, I just came in from doing that, it was the fuse.
The owner before me switched a lot of wires and where that fuse should have been, it wasn't but that's fixed now, thanks.
Krafty
Ontario Canada
check your connections on your reverse lights, if they cross then you blow your signals to. they run off the same fuse for some reason on the early 80's ones. so the next time they go check the reverse lights to.
S
Seth
Thanks, I'll keep that in mind for tomorrow.
