New Grill and Headlight Bezels
ledzilla
Will Co, IL
Had a little fun installing the new grill, trim, and headlight bezels. Looks much nicer than before. Had to replace the bezels because they were actually crumbling apart and getting harder to keep attached. Figured I ought to do the grill while I'm at it. Unfortunately, there were two problems. One was I couldn't remove the lower grill trim due to a ***** I couldn't remove. The other is that the shinier upper trim really highlights the warp in the hood. Either way, it still looks nicer and I was also able to replace the turn signal bulb sockets and repair some damaged wiring. Had no right hand turn signal, the wire broke off at the socket before I bought the truck.
That looks great.
Not an easy job like most people think it is.
ledzilla
ledzilla
Will Co, IL
No, that was a rough job. Took a few hours and cut up my hands quite a bit. Not even sure how. Just suddenly noticed I had bleeding fingers. The upper trim also kept curving upwards at the ends
Oldhenry1
