eddie bauer
Ive got a little problem with my transfer case. I have been using my 4wd like usual in the snow here in NY. Well I got stuck and went to use my 4wd and I have no 4Hi. I wiggled the lever back and forth and viola I got my 4Hi. Well I went to use it again and I had no 4Hi I pulled it back to 4Lo and 4Lo worked like a charm until I went to take it out then it wouldn't come out of 4Lo. I wiggled the lever back and forth for about 5 minutes and it finally came out and I got my 2Hi. So Im just wondering if anyone has had similar problems. So as far as I know I have a 1356 manual shift T-case behind a mazda 5spd. I havent looked into it very hard yet, but as for the shift forks, 1 engages the front shaft and the other engages the reduction. So the problem could be in the linkage but there isnt much of a linkage so I dont think thats it or its in the selector that moves the forks. Im thinking that the shaft that goes from the external shift lever to the internal selector is slipping and just spinning. Any insight would be greatly appreciated. Thank you
