c6 to 5 speed manual
illinoisbronco
morris, illinois
i have always prefered a manual trans, but i have a c6. what other than the obvious like cutting shifer hole installing pedal would that require? i am pulling the engine this winter to rebuild it and if i am ready that would be an opportune time to swap it.
Miss Kitten
alberta canada
first question is what type of use do you get out of your bronco? ie mostly offroad, is it a daily driver?
there's four different options that you can look into with regards to swapping in a manual transmission. there are the t18/t19 4 speed manuals, the zf 5 speed which is the heaviest duty transmission available or the lighter duty M5ODR which is also available in a 5 speed
just so you are aware no matter which manuall transmission you chose you will have to make modifications to your drive shafts.
illinoisbronco
illinoisbronco
morris, illinois
what about the torque converter? slipyoke? also do you think i can pull one from an f150? there is a pickup graveyard down the road from me.
Miss Kitten
alberta canada
the T18/T19 4 speed manual can be found from 1980-1987ish Bronco's and F-series trucks up to an F-250
from a 4x4 with the 5.0L or 5.8L small block. 351M will NOT work
the m5odr will be found in any light duty truck with the 302 for an engine (it's also found in ford rangers with the 4.0L)
the zf is found in 92-96 f-250's with the 5.8L only
of course you have to make sure that no matter what the donor vehicle is a 4wd
you don't have to worry about the torque converter as that's only needed for automatic transmissions ;) /emoticons/[email protected] 2x" width="20" height="20" />
however i would highly recommend buying a new flywheel and pressure plate. if you're going through the effort may as well start everything off as fresh as you can. the ***** cylinder/master cylinder may be reusable but for the $40 to replace both it's the best route. i would also probably reccommend new bell housing bolts just for the ease of it
Miss Kitten
alberta canada
Your a pretty smart girly wirly, haha. Good to have to around...
wow thank you ape
that's a hellava compliment so i'll take it :D /emoticons/[email protected] 2x" width="20" height="20" />
i've just been around fords for far too many years of my life :blush:
and illinois if you have more questions feel free to ask them. i'll do my best to help you with the answers/solutions
