somethings not right
ilystbronco
long island NY
my bronco is not running very good i used this nhra approved fuel additive/booster the last time i filled up and when i put gas in it againthe bronco feels like it is lagging and lossing power / sort of holding back, anyone have this problem what could it be? my boss(mechanic) thing it might be something wth the injectors. what do you guys think?
snowman74
Oklahoma
I doubt very seriously if the additive had anything to do with it...but we don't have enough information to go off here. Did you make any changes/repairs/etc to the bronco before it started running poorly? Did you fill up at a station you are familiar with? It could be water in the gas, which can be remedied by adding a quart or so of denatured alcohol to your gas. But, that's purely speculation. Give us some more info to go off, we'll try to help.
Snowman74 :)>-
I
ilystbronco
long island NY
na i didnt make any changes or repairs and its the same station i always use. but i do have a big crack in my y pipe.
snowman74
Oklahoma
I'm with Miesk5...are there any check engine lights on? You may need to check and see what codes it's throwing out at ya. A cracked Y pipe? How many miles on it since you replaced your 02 sensor? Was the problem all the sudden like, or was it gradually coming on?
Snowman74
I
ilystbronco
long island NY
the problem just happened out of no where tge other day after we filled it up with gas.and the y pipe has been cracked and the check engine light is on because of the y pipe i think.
Penticton , Canada
You need to find out what the code or codes are and go from there. If because of the crack the o2 srs tripped a code there still could be more recent code that my have to do with your current problem.
Need those codes to properly diagnose
keeprollling
Los Angeles
I felt like I lost power last week, it turned out to be that my front passanger side brake pads were sticking and keeping pressure on the rotor. No wierd sounds, no brake light, and no brake smell, it made me worry.
I
ilystbronco
long island NY
ounce in a while it will idle weird like its down a cylinder (as my dad put it) but the plugs and wires and all that are only a year old and i checked those and they looked fine. also one time it did bogg out but it does that very rarely only a couple times what does that mean?
I
ilystbronco
long island NY
today the bronco started to idle high , at like 2000 rpm and i sprayed some wd40 on the throttle body were the cable is and nothing happened .therer could just be dirt in there from the other day but could this have to do with it?
bobstrat
beautiful trenton, n.j.
mine idled at 1500-2100 rpm when the plenum gasket was shot. try spraying a little carb cleaner around the base of the plenum. if it picks up you found your leak. i found mine with a small block of wood that i covered the throttle body with while she was running. cut off the air supply and she still ran fast. so she was getting air somewhere. i have, however, been discouraged from using that technique as i've been told that could cause the gasket to be sucked in. but if you exhaust all other possibilities, maybe try it very briefly. you'll need an air leak roughly the size of your brake booster hose to cause it to run at 2000 rpm. it aint gonna be one of those little plastic lines.
I
ilystbronco
long island NY
nah i didnt see any leaks.but i bought some more additive and im gunna try it again because i think maybe something got clogged from the last time i added it so ill try it again and see if it still runs like shit, ill let u guys knoiw what happens. also how much do you think a muffler shop would charge to weld my y pipe crack were the 02 sensor plugs into?
firelt90bronco
Ask me about my job
northeast
Check your fuel filter and make sure your fuel pressure regulator is putting out the right pressure.
