Gas Mileage
reyns4x4
OK here goes i have a 93 5.8 liter bronco 4x4 of course. i replaced the engine i bought a block and heads from advance auto (didn't have time or plce to do it myself). new plugs new wires and cap and rotor. stock suspension with bridgestone duellers32x11.5 M/T tires. on a full tank i'm averaging 200-250 miles and it also seems to hestitate when i accerate in lower speeds. any info will be helpfull i'm going to try resetting the timing. also new motor has only 1500 miles on it.... thanks in advance......
Well for one the 32 has a very small thing to do with it.
I havy a 96 with 351 i get about 350 miles, and my motor has 130,000 on it.
Do you know what your gears are in your axle that might be what wrong to
bigtrux
bigtrux
Murrieta,CA
Well for one the 32 has a very small thing to do with it.I havy a 96 with 351 i get about 350 miles, and my motor has 130,000 on it.
Well reseeting the timing to seemed to help i'm getting better gas milage fer a bronc anyway lol ... i also replaced the fuel pressure regulator. doing pretty good.. thank fer all the advice...
keeprollling
Los Angeles
My 92 Bronco 4x4 was getting about 6 MPG maybe a bit more when I got it. After a few weeks of owning it and a couple of fill ups, I had a Flowmaster installed and a catalytic converter removed. In order for my bronco to pass smog in California I also had to change some sensors. After doing those changes, I filled up a few more times and I was getting 6.66 MPG all three times I filled up. After that I did a tune up and added E3-40 spark plugs, quaker torque syntethic oil, and a Heavy Duty fram oil filter. The last two fill ups I have gotten 6.9 MPG. I need to do better. My next step is to work on the intake, I was looking into a k&n filter that I can customise for the truck rather then buying the whole kit which runs around $200.
Does anyone know about the tornado and if it works? Do Broncos come with two catalytic converters? I also am planning on removing the top and adding a softtop to reduce weight.
I am planning on getting 4 inches lift and 33inch tires, but before that I need to bring that number way up, similiar to those numbers like the member who was getting 12 MPG.
I forgot to mention, My engine is a 351 with 280000
bigtrux
bigtrux
Murrieta,CA
sorry about the caps yardape and everyone else bad habbit... my axle tag says i'm running 8.8 with 3.55 gears....
Chris929
Pleasant Dale, Ne
I have an '85 and I used to think that I should have got one at least a year older so I would have FI and get better mileage. When I first got it I was lucky if I got 3 mpg out of it. (351 with a Holly 4 barrel) But after a carb rebuilt and some new plugs I'm getting 11-12 with a NAPA filter if I drive it just on the light side. Guess I'll stop complaining.
keeprollling
Los Angeles
I have been getting better mileage. I tried one of those tips in the post by SeaBronc. After the second fill up after my tune up I was getting 7.9MPG. I filled up Yesterday, I am getting 9.6MPG. All I did was added accetone to the gas tank. I am still working on getting the cold air intake and throttle body spacer installed.
wtfdissux
Buffalo, NY
a few Ideas in addition to those mentioned how about a shift kit (B&M makes a great one) and make sure your wheels have no brake drag good bearings in axles and so on and.....
what are some of you complaining for I get 204 per tank If I baby it when running the 33's and when running the 235/75r15 I get a max of 243 (know because thats when I ran out of gas) but the speedo is off with the bigger tires so is prob. around the same
we're getting 14.9 mpg now, primarily on a regular, almost daily 20 mile highway trip; there are about 12 traffic lights of which we stop at half; speed limit is 55 mph
We lightened the Bronco of about 100 lbs of crap and spend $ on prevent. maint. overkill.
chongo469
My 90 bronco 5.0L w/ aod trans is ok on gas.........when you consider i live in seattle and gas prices are up over $4.00...in places here....It takes me a $100.00 to fill her her and i get around 12-13 mpg..BUT...........I LOOK GOOD in her B) ...and thats what matters
