Rear ABS Sensor, or VSS or same thing help!
96Bronco
On the way home from a trip to PA, my transmission started banging through the gears, ABS light on, Spedometer stopped at zero, O.D. off light blinking, and my NAV started acting funny. At first i thought it was a problem with the transmission directly, upon some research on this board i think its the VSS. Is this the sensor on the rear Diff? I have a 96 5.8 automatic, the part autozone game me looked nothing like the senor i removed from the rear. Am i in the wrong spot or did they give me the wrong sensor? in addition, any idea why this happened? I was under the impression that this isnt a sensor that wears out. any info is appreciated
mbtech2003
cape cod, mass
it could be the sensor because mine has the same sensor and when my rear end blew the speedo went crazy. i would get a sensor from a ford dealer. their is just something about autozone electrical parts that i just dont' trust. oil-filter oil ok but not somthing important such as a speed sensor or other calibrated sensor. :)>-
Azone can read your code & give you a "print-out" ....!
(You will prob. have more than (1) code to read)......THEN it's up to you..!
Remember, Auto parts stores computers are "garbage in/out" ..!
If you don't supply the right info. on your veh. ....you WILL get a wrong part.
MOST of the parts counter code read-outs cannot be understood by you or the counterperson (they're not trained troubleshooters) .....so it's best to have an SAE mech. look at it.
johnski
VSS part # from Ford is F85Z-2L373-AC. Had to get one when me and a buddy adapted a VSS to my rear Dana 60 that replaced the 8.8.
