I think it is too much $
I would have to inspect EVERYTHING bec the seller wrote, "NOthing wrong with it, just wanting something different" BUT FAILED to mention "Cracked windshield, ..., driver's side front fender is beat up" and whatever else the seller is not addressing.
Also, ask for a long test drive;
Besides the usual visual, driveability and leak checks, look for:
- oil pan rust - our's formed spots @ 62k miles - sand it down and prime/paint it w/Rust Bullet® Automotive) & high temp. paint - too time-consuming replacement for such a basic thing as not having better gauge and undercoat/paint by Ford
- radiator plastic side seam leaks, esp. during engine cool-down period/overnight - our's leaked @ 50k miles & again just recently - look for leaks after engine has cooled down, esp overnight
- tranny - look for good shifts, clutch operation
- see the maintenance records; fluids/filter;
or on-line dealer service record summaries (Ford is adding entries now), etc. at Ford myford.fordvehicles.com (need VIN) & must register if you haven't already for your other Fords.
- rust in inner rear fender lips, bottom of B pillars and bottom of tailgate (fender lips are rusting due to Ford's flawed spot weld process on the inner (tub) and 1/4 panel that lets moisture & debris in the seam) - A Bronco may need extensive & $$$ patch or full panel replacements...
check tg drains for clogs/rust..check weather seals, esp the outer ws on glass
- radius arm bushing deterioration (I coated em w/pure silicone, from day 1) but replaced at 80k miles w/Daystar polyurethane bushings
- ball joints.. costly if not DIY
Car Fax is ok, but they did NOT list over $5k in single accident damages on 3 of our past vehicles; & our ex-92 Van had less mileage listed than when we sold it according to a CarFax report 2 years later... they did nothing after we contacted them.
- cracked exhaust manifold/Y, etc.
- roof/gutter area cracks (mostly appl. to earlier years)
- emissions air check valve & cat. converter (AIR) tubes tend to rust early; as does the AIR tube; buy locally or from pciinc.com
- radiator core supports, lower, it rusts mainly on passenger side, PIA to replace
- body mounts and frame rust
do a SELF TEST - my pal BroncoJoe at
a Self Test by BroncoJoe19
http://broncozone.com/topic/14269-code-reader/page__pid__74587__mode__threaded
Look Codes up in my broncolinks.com site using the new Search function.
- transfer case operation - electric push button motor/connector is a prob. area; usually usually a broken travel stop or the motor connector is fouled, etc.
Also the Check Engine Light (CEL) comes on when the electronic engine control system is not working properly. The check engine warning indicator comes on briefly when the ignition switch lock cylinder is turned to ON, and should turn off when the engine starts. If the check engine warning indicator does not come on when the ignition switch lock cylinder is turned to ON or if it comes on while the vehicle is moving, the system is malfunctioning
If the CEL does not light up at all when starting it; then suspect that someone removed it.
GL!
