SDBronco91
Hey guys I have a 95 Bronco EB 351, and ever since i replaced my radiator (put a hole in it on a trail), I have had the hardest time with water leaks. First my thermostat housing was screwed up, so i replaced it. Second, I had to replace the water pump. Right after I drive it, I have no problems. There isn't any leaking. However, give it about 9 or 10 hours, and there is a small puddle. It looks like it is dripping off of the crankshaft pulley or right behind that. Other than a bad head gasket, could it anything else? I was also thinking about the heater core because whenever I turn the air conditioning on i smell antifreeze for a few minutes, but there isn't any leaking on the inside.
