vacuum diagram 1973
Yo M,
73 Bronco 5.0 With A/C by Ford
Guessing it's same for without A/C
chrlsful
S. Amherst, MA 01002-1827
yeah, nota lot that early. Just wait a few yrs tho.
(I C no PCV valve in there, do I? I like a 'closed pcv system' for 'pollution' and 'cleanliness' to motor). May B I just can't reada chart.
Loop I use for this (pvc only, i6 ThriftPower) is back of V/C isa pcv (witha V/C baffle to prevent oil contaminated air) hose to manifold vac. Frnt of V/C isa 'cap' easily removable for crankcase oil top offs centered bya nother hose that mounts to A/C Housing for baffled (clean) air. This completes a circuit of clean air venting the crankcase...
Use of some webers disallow this circuit. Now, that is a pre/post '73 solution. Miesk may have a " '73 exact " chart up there...
johnnyreb
West Virginia
Try Green Sales-just type in Green Sales in the address bar and it will come up. They even have a video where you can take a tour. The place is near Cincinatte,Ohio. They have a huge amount of part for Ford and Mercury. From cars to big trucks and in between. Mike,you might also want to check it out and add it to your list
tsebalj
