Intro and Advice?
yo H,
Try computer key board clean and give the hole a shot.... no pun intended
Or wait until ready to give engine a turnover with sending unit removed.  Be ready w/rags or cheesecloth to see what comes out.
This is by Ford
"...NEVER reuse an oil cooler from the failed engine. A new oil cooler must be installed if not already
provided on the replacement engine. Engine lubrication system priming and purging MUST be performed before starting any replacement engine, or on an engine that has had a major repair. Doing so helps to ensure the life of the engine, andprevents you from having to deal with a costly repeat
engine replacement.
Verify the correct amount of oil is in the engine crankcase
Install an engine oil pressure gauge
Disable the fuel supply shutoff (inertia) switch to prevent the vehicle from starting
Crank the engine in 15-second increments, allowing a 30-second cool-down pause between each cranking period
Continue this procedure until oil pressure is observed on the pressure gauge, plus an
additional two minutes (short durations) to ensure lubrication system is purged
Overheating can cause severe engine damage.
For this reason, it is CRITICAL to ensure the cooling system is properly filled. Always refer
to section 303-03 of the vehicle workshop manual for specific cooling system fill and bleed
procedures.
NEVER use impact tools to remove or install a knock sensor. Use of impact tools and overtightening the knock sensor mounting fastener can destroy the sensor and cause engine failure.
FINAL INSPECTION
CHECKLIST
STEP DESCRIPTION
1 Remove/clean/inspect/install reusable parts and components
2 Install new oil cooler, if not equipped on replacement engine
3 Prime and purge Lubrication System before starting the engine
4 Check/adjust fluid levels, ensure proper cooling system fill
5 Allow engine to warm up to operating temperature
6 Verify oil pressure is within specification
7 Verify coolant level
8 Check for loose connections/leaks, adjust/repair as required..."
H
harbinger
So if I'm reading that correctly, I should purge the engine before firing it up because I took the oil pan off?
Am I ******** for asking if I have an oil cooler? I didn't think there was one on factory.
Or are you saying I should do that if I let the oil blow out of the pressure gauge hole?
Thanks again for the help, I'm getting ready to put everything else back together. I can't wait to hear the new exhaust.
Elmo
Forsyth Georgia
I believe what M was saying is; in reference to your question about checking the oil pressure sending unit hole for a possible blockage you could.....1- use compressed air to blow it out. (I my self would probably use break cleaner then air), OR 2- you could ensure the sending unit is out and spin the engine over with the ignition disabled ( you DO NOT want the engine to start while you have the oil pressure sending unit removed) and catch the oil, and any chuncks/blockage that comes out, using rags, cheese cloth, or an empty clean container of some sort.  Now as for the purge. YES you should "purge" your engine. Now this "purge" is essentially prelubeing the engine. By following the procedure as mentioned you are/will be pumping oil throughout the lubrication passages in the engine so that your bearings are not dry. You must use prelube/assembly **** upon assembly of an engine  on any two surfaces that will be rubbing or moveing against each other. This prelube will not last very long and that is why its improtant to Purge the oil system.Purging also verifies that the oil pump is functioning and pumping adequate oil press prior to starting an engine.
Most likely you do not have an oil cooler. IF you do it would originate from an adapter and oil lines that are connected to the block where you oil filter is.
Gryph
