Hey fellow Bronco fans, I recently purchased my first truck and found a "steal" on a bronco (I got it from a guy who sucked at being mechanic). 89 5.8 c6 137k on the odometer.
So I have a few projects lined up and I would like to do them as efficiently as possible. Here's a breakdown, problems first, maintenance after:
Oil Pressure: Starts fine but after a few minutes goes to zero at idle and spikes back up to normal sporadically above idle RPMs.
Valve Covers are leaking
Harmonic balancer is a little wobbly and leaks oil from the front.
Timing Chain: not sure when last replaced (if ever)
Water pump: same
What I've done: fix all three window motor regulators, replace transmission pan and filter, oil change, coolant flush (in process).
So here's my tentative plan for the big project. I have already ordered a new double roller chain and sprockets, water pump, felpro valve cover gaskets, front main seal, harmonic balancer, mech oil gauge, spark plugs, plug wires, distributor cap and rotor, radiator hoses, thermostat, PCV, and timing cover gasket set. I would like to replace all at thesame time to save repetition. The problem I am having in my head though is that I feel like i should replace the oil pump and pan gasket while I have everything apart so save me from having to take all the same items off again to get back to the oil pump if the oil pressure is still low after replacing all the seals. (the felpro timing cover gasket set I ordered says that I have to use the matching oil pan gasket, which I have.) I guess I just answered my own question about necessity of replacing the oil pump there, but thanks for providing a medium for me to communicate with myself through. /emoticons/[email protected] 2x" width="20" height="20" />
1. While on this line of thinking, I keep seeing that I should check the bearings while I have the oil pan off.
2. At this mileage, should I be worried about the bearings?
3. Could the possible cause my harmonic balancer wobble?
4. Should a decent (if low in experience) shadetree mechanic attempt to change out the bottom end bearings?
5. Do I really have to change out the pick up tube when changing the pump or can I just clean it?
6. I had to change the transmission pan because someone over-torqued it before or something and the bolt holes were all a little taller than the rest of the sealing surface, and I'm afraid that will be the same issue with the oil pan, has anyone else had this problem?
I have done a good bit of searching and learning and I appreciate all of you for being here to answer all of us new bronco owners' questions. I hope to one day pass the knowledge along.
Water pump: same
