Highlighted posts from Tuesday, Apr. 05, 2022
  • Thread starter Top stories on BroncoZone.com
  • Start date
T
Guest
Click here to view on the web
Highlighted posts
April 04, 2022 * 18 posts * 181 views
Wishmeluck said: I started pulling apart a 351w out of an 82 Bronco to rebuild and when I pulled off the distributor cap I noticed the rotor looks veeeeery different from any other I've seen (image ... Read more >>
March 29, 2022 * 89 posts * 1,119 views
johnnyreb said: No I never had it at the time I bought the bronco. I bought the bronco. For the fender and bumper---it did have a bad rod bearing.---long story about that--after I had it towed ... Read more >>
March 30, 2022 * 20 posts * 343 views
L\Bronco said: Does anyone know where to find a center cap for the sport steering wheel? I found a wheel for my 79 project, but its missing the center cap and horn button. Any help is appreciated, ... Read more >>
April 03, 2022 * 6 posts * 66 views
mudbug6483 said: I've had my 82 for about 23 years now and the turn signal switch broke last week. I thought it was a tilt column but ive never had to move it. so ive got 2 questions. 1 do you ... Read more >>
March 31, 2022 * 9 posts * 291 views
Tbeck said: Just like the title. Very noticeable at a light touch on throttle. Idles fine, heavy throttle also fine. Rig has 178k, no leaks etc. What say you, Broncozone? TBeck Read more >>
April 03, 2022 * 4 posts * 119 views
M1llionb said: Hello, my 86 is back in business as it wasn't turning on for a long time. Finally got it going! Yes!!! But I'm getting a lot of chirping from the alternator belt. I tried YouTube ... Read more >>
March 30, 2022 * 18 posts * 382 views
paul rondelli said: Congratulations on the Bronco Make sure you have a end goal in mind. 1) lifted trail rig less than 6 inches. re-gear needed but not absolutely necessary 2) upgraded lifted trail ... Read more >>
March 29, 2022 * 13 posts * 372 views
chrlsful said: dont like them mostly as R a ubitiquos addition to so many bronks (admittandly the 1st gen, mine). I use a Kool Rest as it's easily in/out, era correct (aahahaha) and does not ... Read more >>
April 05, 2022 * 4 posts * 20 views
L\Bronco said: Hey Guys, I have posted a few picts here and there of my work in progress. I thought I'd try my hand at a build thread. I only started posting recently, so sorry if this isn't ... Read more >>
March 29, 2022 * 61 posts * 947 views
chrlsful said: any kit still has to B adapted (to their way of engineering) and is expensive. I have so many comments on this install I cant concieve how to enter them (several pages w/my kybd ... Read more >>
Continue reading...
Similar threads
T
Replies
Views
1K
T
T
Replies
Views
802
T
T
Replies
Views
737
T
T
Replies
Views
599
T
T
Replies
Views
950
T
