Highlighted posts from Tuesday, Sep. 27, 2022
  • Thread starter Top stories on BroncoZone.com
  • Start date
T
Guest
Click here to view on the web
Highlighted posts
September 22, 2022 * 10 posts * 177 views
mikefamig said: What is the normal state of the thermactor bypass valve on a 1989 351 windsor (no vacuum signal applied)? My valve does not hold vacuum and I would like to know if it is directing ... Read more >>
September 20, 2022 * 8 posts * 215 views
Motoxman56 said: I am I'm need of a 351W for my 1985 Bronco 351W. The one I removed was Frozen and cylinders would not clean up after doing a test bore. I am interested in one I found that I would ... Read more >>
September 22, 2022 * 5 posts * 183 views
mikefamig said: I got stuck and had to tow it home. The transmission has been shifting a little funny after sitting for many years and I wasn't too worried about it and put it low on my priority ... Read more >>
September 21, 2022 * 31 posts * 739 views
Motech said: You can test that back pressure before you go cutting and gutting on a whim. Find yourself an 18mm threaded fitting, same as old spark plugs, something you can thread into a hole ... Read more >>
September 26, 2022 * 3 posts * 56 views
Carlos Riestra said: Mi Bronco color Desert Copper 1995 sumamente raro el color. San Juan, Puerto Rico 🇵🇷 Según Marti Report 1en 147 de 28,000 ese año. Mi otra Bronco Toy Car 1993 ( verde y negra ). ... Read more >>
September 20, 2022 * 15 posts * 435 views
goodO1boydws said: Actually the changeover from R12 to R34a WOULD NOT BE very expensive, if you didn't have leaks. THE SMARTEST, MOST COST EFFECTIVE THING TO DO RIGHT NOW IS TO PRESSURIZE THE SYSTEM ... Read more >>
September 21, 2022 * 83 posts * 5,744 views
L\Bronco said: Road test again last night. Smooth as silk at 75! [image] Read more >>
September 22, 2022 * 37 posts * 3,076 views
Motech said: I agree with @L\Bronco that your downshift cable is too tight. Hold your throttle wide open, push the adjustment button on the cable retainer and let it snap to it's spring-loaded ... Read more >>
September 21, 2022 * 5 posts * 1,769 views
johnnyreb said: Better yet,put a posi in it . No 4 wheel part to get or maintain. Read more >>
Continue reading...
Similar threads
T
Replies
Views
892
T
T
Replies
Views
1K
T
T
Replies
Views
828
T
T
Replies
Views
939
T
T
Replies
Views
598
T
JohnK
