Highlighted posts from Tuesday, Aug. 16, 2022
  • Thread starter Top stories on BroncoZone.com
  • Start date
T
Guest
Click here to view on the web
Highlighted posts
August 14, 2022 * 2 posts * 65 views
YJ351LC said: Need some help. Spliced in a jumper wire for the power to the tailgate key switch a couple days ago. Everything worked fine (dash switch and key switch) for a couple of days. Went ... Read more >>
August 15, 2022 * 2 posts * 18 views
M1llionb said: I need a radiator hose to replace the present one. I've tried all local part retailers (Autozone, Advance, O'reilly, Napa) and no luck. I've even purchased on Amazon and it's not ... Read more >>
August 10, 2022 * 4 posts * 150 views
Harleyjasondavidson said: Hey folks, Anybody know if a rear seat from a 92-96 will fit in the 1981 year? The ONLY bronco in any of my local junkyards is much newer than my 81 who is missing her rear seat. ... Read more >>
August 09, 2022 * 2 posts * 134 views
elijha said: Hello all I have a 1974 with the 320 engine in It.I have not worked much on this model truck more in to the VW and Older Fiats . It did catch fire, Plug from the distribution to ... Read more >>
August 15, 2022 * 1 post * 17 views
phragg said: Hey All, I recently purchased a 1986 Ford Bronco II, but the driver's side window is stuck down a bit. Upon further inspection I realized that the Window Bracket Assembly is cracked ... Read more >>
August 13, 2022 * 1 post * 80 views
RR-Texas said: For Sale OEM, Factory, Ford, Hi-Tech, Theft Preventative Module $750.00 I had her scheduled for an E40D rebuild the first week in March, 82 year old mother fell Trama Surgeon Required ... Read more >>
August 09, 2022 * 4 posts * 221 views
goodO1boydws said: Do you mean the rear of the vehicle is leaning sideways when no one is aboard and there is not an unequal EXTRA LOAD in it? If so, the first step is to figure out what is causing ... Read more >>
August 09, 2022 * 5 posts * 315 views
Black Bronco King said: I will opine on your situation. I would go with 17" tires and steer away from 33X12.5/15 more details on with classic rims from advice. Well, the 15" tires have a lower load rating, ... Read more >>
August 09, 2022 * 3 posts * 207 views
Motech said: Those are thermal vacuum switches, likely for EGR, Spark Control, maybe Air Injection, etc. New t'stat housings are only ten, maybe twenty bucks, and by application will come with ... Read more >>
August 11, 2022 * 6 posts * 417 views
Emelio said: Hi B-Co Kid, You have quite a list with upgrades; My '86 Bronco XLT has the same blue navy interior and I'm also thinking of major upgrades similar to the ones you've done. I'm ... Read more >>
Continue reading...
Similar threads
T
Replies
Views
766
T
T
Replies
Views
899
T
T
Replies
Views
893
T
T
Replies
Views
1K
T
T
Replies
Views
941
T
JohnK
