This past weekend, I put on the Herculiner Do-it-yourself bedliner stuff in my 84 Bronco. I've already stripped out the complete interior, seats, trim, wiring, etc., but had a few cracks and holes in the floor that needed to be welded up and a small area of rust on the passenger side where a stereo power wire shorted out and burned thru. Took about 2 hours to slowly weld up the holes and cracks, without burining thru the thin floor metal. A bud took a wire wheel and cleaned up some old spots of factory sealer and carpet glue, then we sprayed primer on the bare metal areas and the welds. Another 2 hours to tape off the edges and something like 75 holes in the floor and bed. The Herculiner went on smooth and easy, and the instructions offered good advice. I had just enough in one gallon to apply a thick first coat, and stretched it thinner for the second coat 6 hours later. I coated the cab and bed floor, plus the bedside panels on the inside up to the top lip. I had already done the inside of the tailgate with Dupli-Color spray-on bedliner. That stuff is alot thinner but has a smoother finish than the Herculiner. Only real problem I had was clean-up after the first coat. I could only find acetone for a solvent/cleaner. It worked fine on the brushes and roller, but dissolved my Latex gloves. Once the Herculiner dries on your skin the next day, it peels off easily, but it won't come out of clothing. Will post pics at Superford.org after Memorial weekend, JSM84
