Hi guys.
this will be my project tread/worklogg for my 1980 ford bronco.
i will in advance appologice for spelling mistakes. im no native english speaker.
actualy i live in Norway B)
Car info:
- Car name: The Nigthmare
- 1980 bronco fullsice
- Engine 302 EFI
- Transmission: C6 with a axle drive ratio of 3,50:1
- rear axle: ford 9" with a minispool installed.
- Suspention: Stock
- 2,5" exhaust wit a single simons blowtrogh Muffler
- Interior : gray leather
Plans for the car:
No big plans for now, but i know i wont do a lift and that il be doing some offroading in it.
Day one : 22 august 2009
Me and a good friend of mine grabbed his chevy and went to pick up my new toy.
and man do i look forward to getting this bad boy on the road agean...
First day of work on the car: 23 August 2009
So today i set out w a few goals.
1 figure out what engine it has
2 figure out what transmission it has
3 figure out whats wrong w the rear axle.
4 get a general idea on how bad the rust problem is.
so what did i figure out?
Engine:
well i dint even bother too look at it....
Transmission:
what i know now is that the options on the gear shift lever is: P - R-N-D-2-1 so no 3rd gear to choose.
il look more into the transmision later.
Rear axle.
well Both of the drive shafts are fine so i pulled out the third member.
and this is what i found when i opned it:
Now this cannot be good. :blink:
so i looked more into the gears and what i found was that it has completely shattered atlest one of the internal gears in the differential.
and this is the info i now have on my rear diff: its a open diff and it has 28 splines on the axle shafts.
Il come back w a more detailed description and more pics of the damage once i have opned the diff and have rebuilt it. (maybe il make a howto)
The rust problem
Well here i have some work to do i see. BUT its not nearly as baad as i feared it whoud be.
Drivers side floor: What floor? i have some work to do here i think.......
Driver side door frame and floor: More holes and even more work to do
Passenger side floor: Now this is not bad at all. no holes and only ligth rust. this will be fixed fast
there is also some baad rust in both of the doors and tailgate. but i think il just buy new doors and tailgate.
and last i took some pictures of the car.
Not too bad inside
I need to get me a new Grill
Passenger side, (NL sign comes from the previus owner)
Up on stands and waiting for some new parts for the differential
Car info:
- Engine 302 EFI
- Suspention: Stock
Plans for the car:
Engine:
Transmission:
Rear axle.
The rust problem
Not too bad inside
