yo BRAD,
My broncolinks.com site is frozen in cyber space right now; so here is some info from my MS WORD NOTES; none have been validated though, so compare to other sources
77 Early Bronco 302 Emissions Diagram
Early Bronco CA Smog Equipment (V8)
1966 all PCV 1-AIS
1967 all PCV ACL 1-AIS
1968 289 200 PCV ACL 2-AIS
1969 302 PCV ACL
1970 302 205 PCV ACL 3-EVAP
1971 302 205 PCV ACL 3-EVAP
1972 302 PCV ACL 3-EVAP
1973 302 137 PCV ACL EVAP EGR
1974 302 5-137 PCV ACL EVAP EGR AIS SPK
1975 302 ACL EVAP EGR AIS EFE 1-OC 1-FR
1976 302 ACL EVAP EGR AIS EFE OC FR
1977 302 PCV ACL EVAP EGR 4-AIS OC FR
Notes:
1.Some models only
2.M/T only
3.CA only
4.Except Federal A/T
5.Only engine available in CA
Definitions:
PCV
Positive Crankcase Ventilation
ACL
Air Cleaner
EVAP
EVAPorative Control System
AIS
AIR Injection System
SPK
Ignition Spark Control
INFO SOURCES:
check Library; mine has All Data on-line for free but in-library use only;
All Data uses the Ford docs
Chilton; many local library's offer free on-line access for their members;
just log-in w/your library Card # and password; incl. all Broncos, & many MAKES! 1951 to Current;
some years (85-96, I believe) include: FULL Technical Service Bulletins and Recalls, Labor Hours per repair (plug in appl info); Wiring Diagrams, Vacuum Diagrams (in DRIVEABILITY AND EMISSIONS CONTROLS Section), Specifications (torques, etc.) & Maintenance Intervals
or
Auto Repair Reference Center Repair Manual, Mostly Chilton; many local library's offer free online access for their members; just log-in w/your library Card # and password; incl. all Broncos, & many MAKES! 1951 to current; some years (85-Current, I believe) include: FULL Technical Service Bulletins and Recalls, Labor Hours per repair (plug in appl info); some Wiring Diagrams, Vacuum Diagrams (in DRIVEABILITY AND EMISSIONS CONTROLS Section), Specifications (torques, etc.) & Maintenance Intervals
Source: by arrc at
http://search.ebscohost.com/
Autozone Repair Guides & Wiring Diagrams (click vehicle, year range) & go to Chassis Electrical & scroll for Wiring Diagrams; MUST REGISTER TO VIEW; select year, make, model, engine size and go to appropriate section
Source: by Autozone
is less detailed than the Library Version
http://www.autozone.com/autozone/repairinfo/repairInfoLanding.jsp
