Smog for a 1977
brad6920
Magalia, CA
I have been looking to get an early bronco for some time and have looked at a number of them. I looked at a '77 but it has no smog on it and will need to be smoged here in California. I have looked at JBG and Tom's broncos but can't find anything for smog pumps etc. Can anyone point me in the right direction?
Thanks in advance.
I thought that vehicles after "x" year didn't need to be tested?
Hi Brad..,
As Skitter mentioned, I think it's (calif) 20yrs. & longer/older don't req. a smog test.
Also, I don't think '77's had smog pumps.
But.., check me on both points.
Don't search but call.., Toms Br. parts or Wildhorses 4x4 there in Cal. & ask them what's required.
brad6920
Magalia, CA
Okay, here is what I found out. Here in California '76 and '77 trucks need to be smoged. The '77 does have a smog pump and from what the guy at Wild Horses said, there is a lot of stuff to go on it. All the brackets and air cleaner will have to be found used which could be really difficult. He also said he wouldn't get a '76 or '77. At least here in California.
Good info..., thanks for the update.
One could find a donor veh. in a boneyard & collect all the smog stuff for a 76-77 but you would have to really know what to look for.
A "bone-stock" (Calif.) 76-77 would be OK to purchase.
Good luck with your search & let us know what you find.. >:D< <'>
yo BRAD,
My broncolinks.com site is frozen in cyber space right now; so here is some info from my MS WORD NOTES; none have been validated though, so compare to other sources
77 Early Bronco 302 Emissions Diagram
Early Bronco CA Smog Equipment (V8)
1966 all PCV 1-AIS
1967 all PCV ACL 1-AIS
1968 289 200 PCV ACL 2-AIS
1969 302 PCV ACL
1970 302 205 PCV ACL 3-EVAP
1971 302 205 PCV ACL 3-EVAP
1972 302 PCV ACL 3-EVAP
1973 302 137 PCV ACL EVAP EGR
1974 302 5-137 PCV ACL EVAP EGR AIS SPK
1975 302 ACL EVAP EGR AIS EFE 1-OC 1-FR
1976 302 ACL EVAP EGR AIS EFE OC FR
1977 302 PCV ACL EVAP EGR 4-AIS OC FR
Notes:
1.Some models only
2.M/T only
3.CA only
4.Except Federal A/T
5.Only engine available in CA
Definitions:
PCV
Positive Crankcase Ventilation
ACL
Air Cleaner
EVAP
EVAPorative Control System
AIS
AIR Injection System
SPK
Ignition Spark Control
INFO SOURCES:
check Library; mine has All Data on-line for free but in-library use only; All Data uses the Ford docs
Chilton; many local library's offer free on-line access for their members;
just log-in w/your library Card # and password; incl. all Broncos, & many MAKES! 1951 to Current;
some years (85-96, I believe) include: FULL Technical Service Bulletins and Recalls, Labor Hours per repair (plug in appl info); Wiring Diagrams, Vacuum Diagrams (in DRIVEABILITY AND EMISSIONS CONTROLS Section), Specifications (torques, etc.) & Maintenance Intervals
or
Auto Repair Reference Center Repair Manual, Mostly Chilton; many local library's offer free online access for their members; just log-in w/your library Card # and password; incl. all Broncos, & many MAKES! 1951 to current; some years (85-Current, I believe) include: FULL Technical Service Bulletins and Recalls, Labor Hours per repair (plug in appl info); some Wiring Diagrams, Vacuum Diagrams (in DRIVEABILITY AND EMISSIONS CONTROLS Section), Specifications (torques, etc.) & Maintenance Intervals
Source: by arrc at http://search.ebscohost.com/
Autozone Repair Guides & Wiring Diagrams (click vehicle, year range) & go to Chassis Electrical & scroll for Wiring Diagrams; MUST REGISTER TO VIEW; select year, make, model, engine size and go to appropriate section
Source: by Autozone
is less detailed than the Library Version
http://www.autozone.com/autozone/repairinfo/repairInfoLanding.jsp
