yo BB,
WELCOME!
you have a 93, correct?
if so,
Wiring Diagram in a 95 (see #1) - same as the 93
http://broncozone.com/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=5796
Power Distribution Box Diagram in a 93;
Located under the hood on the drivers side fenderwell, on driver's side of the air cleaner housing
**** Fuses feed other fuses in there as well as the ATC fuses in cab fuse block
Inspect ll fuses and test electrically for power on buth sides of fuse while still in holder.
Click next to view layout diagram
Source: by Troll Banned (Bronco Rob, BroncoRob) @
http://www.supermotors.net/registry/media/290853
**** FUSE N; check fuses 1 (ac & heater, & 7 (instrument cluster, turn lapms, rear window defroster, 4x4 & low range ind lamps) and E
Check **** Fuse P; Check fuses 2, 6, 11, 14, 17 & **** Fuse U
Fuse Block Diagram in a 93 Bronco & F Series
Source: by Steve
