ignition switch
broncobum1960
Change ignition switch when removing the old one I shorted something out know no power to the key switch or the dash. help 91 bronco
yo BB,
WELCOME!
you have a 93, correct?
if so,
Wiring Diagram in a 95 (see #1) - same as the 93
Source: by Seabronc (Rosie, Fred W) at Ford Bronco Zone Forums http://broncozone.com/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=5796
Power Distribution Box Diagram in a 93;
Located under the hood on the drivers side fenderwell, on driver's side of the air cleaner housing
**** Fuses feed other fuses in there as well as the ATC fuses in cab fuse block
Inspect ll fuses and test electrically for power on buth sides of fuse while still in holder.
Click next to view layout diagram
Source: by Troll Banned (Bronco Rob, BroncoRob) @ http://www.supermotors.net/registry/media/290853
**** FUSE N; check fuses 1 (ac & heater, & 7 (instrument cluster, turn lapms, rear window defroster, 4x4 & low range ind lamps) and E
Check **** Fuse P; Check fuses 2, 6, 11, 14, 17 & **** Fuse U
Fuse Block Diagram in a 93 Bronco & F Series
Source: by Steve
broncobum1960
Hey Bum,
Welcome.....What are the particulars of the Bronc you're working on?
Have you checked all the fuses? Checked The fusable link at the Starter solenoid?
Its a 91 bronco,is the starter solenoid on the passange side on the fender
broncobum1960
yo BB,
WELCOME!
if so,
Source: by Steve
sorry it is a 91 bronc
Rons beast
Hey Bum,
Yes it is. If the fuses are all ok, check wires at the solenoid that have constant batterypower. One or two have fuseable links that may have been shorted. Sorry to be so vague. I do not have my wiring diagrams available.
Good Luck
Starter Relay pic in a 91 5.8 w/wire identification
http://broncozone.com/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=12001
Source: by shaunmccarron at Ford Bronco Zone Forums
Troubleshooting in 87-91 (from Factory Manual and the Ford Electrical & Vacuum Troubleshooting Manual (EVTM); w/Wiring Diagram & Continuity Testing (Logic Tables); miesk5 Note, It is out of order, so read the 2nd from left page first
Source: by Broncobill78 (Dave) at Ford Bronco Zone Forums
http://broncozone.com/topic/14120-87-91-ignition-switch-info-troubleshooting-guide/
Check for Open in Fusible Link M (BLUE in Color) @ Starter Relay on passenger side inner fender
See Bill's wiring diagram in aove Link; it is @ upper left side if diagram is rotated CW
Should be Battery Voltage to Ground
Yellow Wire to Ign Switch
Most fusible links show a melted, charred insulation when they burn out.
another diagram by SeattleBronco in a 90 shows same;
it shows from M to Connector C202 which is on firewall and other side goes to dash, ignition switch, etc.
