See my;
Replacement, Front Wheel Grease Seal and Bearing & Auto/Manual Hubs in a 96 from Ford Workshop Manual
1 3A329 Halfshaft
2 3C132 (Axle) Rolling Diaphragm Seal
3 3299 Integral Spacer Needle Bearing Seal
4 3123 Bearing, Caged Needle
5 3105 Front Wheel Spindle
6 3254 Spindle Rolling Diaphragm Seal
7 1190 Wheel Hub Grease Seal
8 4221 Inner Wheel Bearing (with Bearing Cup � 4222)
9 1102 Front Disc Brake Hub and Rotor
10 4221 Outer Wheel Bearing (with Bearing Cup � 4222)
11 � Pin (Part of 1195)
12 1195 Inner Lock Nut
13 1198 Lockwasher
14 1197 Outer Lock Nut
15 � Steel ****** Washer (Part of 3B458)
16 � Plastic ****** Washer (Part of 3B458)
17 � Splined ****** Washer (Part of 3B458)
18 3B457 C-Ring
19 1K105 Hub Body
20 � Lock Ring (Part of 1K106)
21 1K104 Cup
22 1K104 Capscrew
A While Rotating Front Disc Brake Hub and Rotor, Tighten Inner Lock Nut to 68 Nm (50 Lb-Ft) to Seat Wheel Bearing. Back Nut Off 90 Degrees (1/4 Turn).
B Tighten to 217-278 Nm (160-205 Lb-Ft)
C Tighten to 4-6 Nm (35-53 Lb-In)
Wheel Bearing Locknut Torque Settings for 80-96 MANUAL HUBS, NOT Factory Auto Hubs; Ford Pickups and Bronco; "...Using a lockout spanner (Ford # T59T-1197-B or equivalent) and a torque wrench, tighten the inner bearing adjusting nut to 50 foot pounds while rotating the wheel back and forth and seating the bearing. Back off the adjusting nut approximately 45 degrees. Assemble the lock washer by turning the inner lockout to align the pin with the nearest hole in the lock washer. To lock it, install the outer lock nut and tighten it to 150 foot pounds. Grab the top of the tire with one hand and the bottom of the tire with the other. Move the tire in and out on the spindle. End play should be less than .006 – inch.).." Thanks to 90beater (Topher, Chris)!!!!
Source: by miesk5 at Ford Bronco Zone Forums
more info in my site @
http://www.broncolinks.com/index.php?index=508
