utsports407
- Joined
- Dec 12, 2009
- Messages
- 12
- Reaction score
- 0
I have a 74' Bronco and keep breaking the u joint where the drive shaft enters the rear end. It is a single u joint. In four months, I've had to replace four. The last one was the heavier duty u joint spicer u joint. It lasted less than 200 miles and seen very few mud holes. I can tell you that the bronco has had a 2" lift (spacers). The angle/pitch from drive shaft to rear end yoke is not a problem. In fact, it looks like there is no more than 1-2 degrees of angle. My bronco will allow up to 15 degree angle. I assume the rear end was shifted upward to correct the pitch when the spacers was installed. Looking at the drive shaft from the rear of the bronco, it looks like it is running straight. When weather warms a little, I'm going to measure from frame to center of drive shaft at one end of drive shaft and do the same for other end of drive shaft to make sure they are equal. The rear end has a mini spool installed.
Can anyone suggest possible problems or better ideals on how to check if drive shaft is running straight from frame.
Oh, I have been greasing u joint after installing.
Thanks
Thanks
