cleaning up engine compartment
JLasvegas
I have alot of unused wiring due to removing my old carb, would it be ok to cut them out of there or would you just tape it all up. I want it to look clean. Im going to buy the plastic coverings that go over wires to make it look a little better, but what to do with all that extra wiring
also since I no longer have the stock carb that was electrically controlled do I need to keep the plug and wiring for checking codes
crazyhorse85
clarksville,tenn
Good question...mine i just cut and used heat shrink tape to make them water tight....I have no future plans of putting any of the emission stuff back...But that's just me.. B) That's the question you have to anwser for yourself....It does clean alot of unneeded mess out of the way.... B)
In cleaning up the under hood mess on mine, some of it my own doing while experimenting, I had to face the same question. And as previously stated by crazyhorse85, it's one of those decisions that get pretty personal. My decision was to cut the cord. I had left a lot of stuff dangling around, "just in case", (the pack-rat code) :rolleyes: . In the end, since I had decided to add a under hood fuse box and eliminate fusible links, move my battery and several other clean up items, I came to the decision to remove the unused junk and make my own wire harness that eliminated unused lines and include upgrades.
All that comes to, as long as you are up to it, Go For It B) .
A couple of evolution pictures below: Top row (when I first purchased it - ultimate mess), bottom row (what it looks like now).
Bronco_Willis
Edmonds, WA
A buddy of mine in his 89 bronco welded special little compartments and ran wires into them. It looks really clean as well
Big difference... Looks much better. The sag pump is purdy too.
0331jhans
