88BroncoBlack
what is my timing rpm and degrees supposed to be on my 88, the sticker in my engine compartment is gone
that sounds like the old... advance it until it pings, and then back it off a little bit.I can look up something from the manual later on but for a quick off-the-cuff answer I'm happy with mine when I get it somewhere between 8 & 11 degrees at idle. To be honest, more often than not once it's set I just I just nudge the dizzy a bit one way or the other every day or so until the thing seems to pull strong and doesn't skip or pop. I'm sure there are plenty of other guys who have different methods, this is just mine. Remember that you don't want to time it with the vacuum advance connected.
Well, yes, I do. I believe that what I said before was 8-11 degrees at idle and if you needed to see it that I would find and scan it for you & here it is. This is a scan of the 88' underhood sticker from the 88' factory manual. If you look closely you'll see that it specifies 10 degrees at 900rpm.does anyone know that actual ford specified settings, mt service manual says look at my sticker under the hood, but that is long gone
I do actually own & use a light. I use it to time to the factory spec. However, it's been *my* experience at least that engines tend to get more & more individual as they rack up the miles so I use the light to set factory spec timing & then adjust it from there by hand until it runs well. If it's happy & purring at spec then great, I'm done, but more often than not the clunkers *I* wind up with usually need a bump in one direction or the other before they're happy.that sounds like the old... advance it until it pings, and then back it off a little bit.OK.. so that's how I did it til I bought myself a timing light./emoticons/[email protected] 2x" width="20" height="20" />
I vaguely remember reading that the base timing should be changed a little depending upon altitude and temperature at the time and location it was set. Once set, the newer computer controlled engines should be able to make the necessary changes to timing should the driver take his vehicle to a different altitude, or should the barometric pressure change. WIth the older vehicles, one may need to bump the timing a little bit.I do actually own & use a light. I use it to time to the factory spec. However, it's been *my* experience at least that engines tend to get more & more individual as they rack up the miles so I use the light to set factory spec timing & then adjust it from there by hand until it runs well. If it's happy & purring at spec then great, I'm done, but more often than not the clunkers *I* wind up with usually need a bump in one direction or the other before they're happy.
Taken from the Haynes manual page 5-17Heres some info , never seen anything with a 351 after 86 with a carb . And there is no EECIV distributor with a vacuum advance , Would kinda make the computer useless .
Well, yeah, I kinda do. You know it and so do I. To pretend otherwise is a bit foolish don't you think ? I believe it started back here: http://broncozone.com/forums/index.php?sho...c=13279&hl= when you said "here is a link to the CORRECT way to install an edelbrock intake directions STRAIGHT from edelbrock not someone that has seemingly decided to be the definative source on everything that rolls on wheels" and yeah, I took that as a fairly personal comment since you certainly intended it as one. Anyone who questions it is free to read the full text of the thread and decide for themselves. When I find a moderator who chooses to *repeatedly* make personal attacks on me and at the same time REFUSES *multiple* requests to deal with the issue privately then YUP, I have a problem. My Email address is no State secret and not only have I requested that you & I deal with our issues privately SEVERAL times but you have chosen to continue to take public jabs at me at ever turn. If you choose to deal with this publicly rather than privately then so be it. I'm DONE asking you to speak with me privately, if you're foolish enough to WANT this to be public then it will be. Just HOW many PM's have I sent you asking to deal with this one-on-one ? I've lost count. You want it, you got it. You *wanted* a public ******* match and now you have one. All you ever had to do was click on one of the several PM's I sent you and this would have been a private issue and over with. Do I really need to go back & post every point of contact or are you willing to simply concede that you and I have issues that you're aware of ?WOW Bill seems you do have a real issue with me
