ColoradoBroncoman
- Joined
- Mar 2, 2008
- Messages
- 8
- Reaction score
- 0
Hi, I have an 94 Bronco, that will not shut off. I can turn the truck on with the key but when I go to turn it off, the key ignition switch just keeps turning in a circle, it does not have the "OFF" position on the switch. I have changed the actual key ignition switch, and it is still the same. What other areas can I change to get the "OFF" position at the key? I would hate to spend 60-85 dollars for diagnostic and find out it was some little spring or cable that I can do myself. Any help would be greatly appreciated.
THANKS,
Rob
THANKS,
Rob
