Tailgate Window Circuit "... is a common (Ford) polarity-reversing circuit with 2 switches.
Each switch has its own power feed; the dash switch through the ignition switch (key-on only) and the tailgate key switch from the battery (always hot). The dash switch normally holds both motor wires to ground, and the key switch normally holds the motor wires to the dash switch wires. When either is operated, it sends one of the wires hot, powering the motor (assuming the latch switch is closed). When operated the other way, the polarity is reversed, reversing the motor's direction. Neither switch is a "master" because neither will work if the other is in the opposite position..."
Source: by Steve83
So, the TG KEY switch is powered by same fuse as the PDL & P Mirrors (if installed as option) - BLK/WHT (Black/White wire)
the Driver's switch is powered by same fuse as the PW - Lt Blu/BLK (light blue/black)
I was looking at
an 84 Diagram (but it is incomplete, so I can't trace what a bad ground wire would do to the radio/etc.) for a pal and noticed that the TG window motor shares same CB/fuses as the Radio and PW/DL & Power Mirrors, in so many words
See the Ground terminal in this TG Harness pic by our MAIN SPONSOR,
Jeff's Bronco Graveyard?
http://broncograveyard.com/images/catalog/zoom/7886TGATEWIRINGHARNESS.JPG 1983-86 Ford Bronco Let's figure this is ok for now.
Now I need to see a complete ckt with da radio for your year and see where it's ground is.
But for now,
our good buddy, Seabronc has posted-up some info;
Locations in an 86 (see #5); G701 Behind IP near RH side of radio; G801 On LH inner fender behind headlights; G802 On RH inner fender behind headlights; G903 At LH side of rear crossmember; G909 at lower LH cowl access hole; G1003 On LH side of frame behind front crossmember; G1006 Rear LH side of frame at rear crossmember; G1303 at LH radiator support Source: by Seabronc
Location, Tailgate Window In-Dash Switch
in an 86;
701 "...Behind Instrument Panel near RH side of Radio..."
Source: by Ryan M (Fireguy50)
So, let's make it ez ck first without going thru a Hayne's or Chilton etc. check that radio ground
