windows
koontreeguy
western mass
are power window doors constructed the same as non power ones? like could I buy a manual regulator and crank and toss it into my existing doors that have power windows after I toss the motor ? that's all
Yes, all you have to do is remove the regulator with the power window and install a manual regulator. You will have to either make a hole for the handle or get a cover that has the hole already in it. If you can't find a new door cover in a junk yard you can list in the Parts Wanted section or buy on e from Jeff's or LMC Truck. You drill out the pop rivits that Ford installed and use bolts from a hardware store to mount the manual regulator in.
If you need more details, just ask :) /emoticons/[email protected] 2x" width="20" height="20" />
Why the heck would you want manual windows???
Because the motor never fails :D /emoticons/[email protected] 2x" width="20" height="20" /> , the less electronic crap you have in a truck the fewer failures you have. I have them and love them. It is the same reason I have seen people wishing they could have a manual crank on their tail gate like the K5.
K
koontreeguy
western mass
exactly :) /emoticons/[email protected] 2x" width="20" height="20" />
good one Fred!
can I add one?
I have seen people wishing they could have a manual crank on their EFI Bronco like my old Schwinn...
good one Fred!
can I add one?
That is why I love my carborated Bronco. Never had a sensor feed it bad information to make the engine either not start or run like crap. :D/ B) :p /emoticons/[email protected] 2x" width="20" height="20" />
