Will Explorer rear leafs give any lift to a Bronco 2
mosskie
Oregon
I read somwhere that Explorer rear leafs will give a Bronco 2 3" lift, is this true?
I just bought an 88 Bronco 2 with about 6' of lift but the rear is lifted on two sets of blocks per side :eek: /emoticons/[email protected] 2x" width="20" height="20" /> . I know this is dangerous and want to lift it with leaf springs or at least enough to lose one set of blocks. Any one have any suggestions?
Yes they would because an explorer rear is mounted on top of the springs like a jeep and if you put it on the bottom you will gain a minimum 3 inches for the diameter of the axle tube . :D /emoticons/[email protected] 2x" width="20" height="20" />
mosskie
mosskie
Oregon
Thanks for the help, I really appreciate the advice without the flaming like some other sites :D /emoticons/[email protected] 2x" width="20" height="20" /> .
No problem we dont allow flaming here it creates extended vacation times . If you have any other questions feel free to ask :D /emoticons/[email protected] 2x" width="20" height="20" />
digs
