caryweaver
- Joined
- Nov 17, 2008
- Messages
- 15
- Reaction score
- 0
They seem to fit the requirements.Will these fit a 1986 bronco?U.S. Wheel - 37 Series Chrome Star Wheels
I was just unsure about the size needed on the center bore... for the manual hubs.They seem to fit the requirements.
Your hubs are about 3 1/2 " in diameterI was just unsure about the size needed on the center bore... for the manual hubs.
I thought it seemed large enough though.
-cw
Do you know what standard backspacing is?Your hubs are about 3 1/2 " in diameter
No, I have 3 sets of wheels, all have a center bore larger than the hubs. Now here is the catch, I got caught by this when I got over excited about a set. The Bronco must have "lug centric" wheels. Some wheels are designed to be "hub centric" Hub centric wheels will not go on a Bronco. Ford went from lug centric to hub centric in the late 90's, right off hand I can't remember which year. After the switch and up until about 2004 they used a 5 x 135mm lug pattern hub centric wheel and after that switched to a 6 lug pattern.Thanks for the info...
One more question...
Do you think the size of that center bore will matter? If it is larger than the hubs...
An easy way to spot lug centric is by the cone shape of the lugs and bores in the wheel. The hub centric use a nut with an attached washer and the wheel has a flat area the washer seals against.
So the short of it is, if you have a Bronco then the center bore needs be a little larger than the hub diameter to allow the wheel to properly center when the lugs are tightened.
