what is this?
Red Green Jr
Duluth, MN
I have been trying to figure out what this part is called so I can get a new one. Its some type of wedge that goes in between the spring perch and the leaf springs, it has a stub on the bottom and an offset hole on the top. I outlined it in the attachment. thanks
Miss Kitten
alberta canada
that's a leaf spring block
some people use larger blocks to gain more lift in the rear, and you can by shims that are angled to correct a pinion angle after a lift as well
Red Green Jr
Red Green Jr
Duluth, MN
But its not a standard lift block. First, its wedge shaped, the back is about an inch tall and it slopes down to nothing. Also, the hole and stub are offset from each other and all other shims that I have seen do not have a stub, they just have a hole all the way through. If the wedge was not there the axle would be moved forward about an inch and be angled too far down.
I dont have a better picture, but its roughly this shape (sorry for the crudeness)
J&SBroncolvrs
Yukon, Canada
This is just a guess, but I think it's part of a levelling kit. Bronco's originally had a rake to the front of about an inch and a half. To level it the smallest spring for the front you could get was 3" higher than stock (I'm guessing) which requires a small lift block in the rear. Like I say, I'm not sure but when I bought my bronco, I was told it had a 3" lift on it, and it has the same block in the rear as yours does.
Red Green Jr
Red Green Jr
Duluth, MN
The only info I can find is that those are factory wedges to correct the pinion angle. I still have no idea where to get new ones though.
Red Green Jr
Red Green Jr
Duluth, MN
I have already been fooled by those, lol. I bought a pair but they dont have a stub, its just a hole drilled all the way through and the angle is too shallow.
J&SBroncolvrs
Yukon, Canada
I can't find them either. I've read about some guys that are good enough to fabricate their own, or maybe hit a wreckers?
Red Green Jr
Red Green Jr
Duluth, MN
I'll probably have to wait until spring and get it from a junkyard
Bronco79
Iceland
If you get a "Spring Center Bolt" that's long enough it will go through the leaf spring and the block and you will have your stub at the bottom.
trhaus
alberta
your best luck would probably be to find a set at a junk yard when i put a lift on my 94 f150 i gave those to buddy for a leveling kit. they are commonly found on stock high-riders or taller stock trucks
BKW
CA
EOTZ5729A (replaced: D8TZ5729A) .. Rear Spring Spacer (Wedge) / Obsolete
Bowman Sales & Service in Bowman ND has THREE = 701-523-3257.
These are NOS - New, Old Stock.
No other Ford dealer or obsolete parts vendor has any.
MIL1ION
Still Da Man
Central Alberta
JohnK
