what do you guys think i need to do to fix this/how hard?
T2HUFF
well after fixing up my bronco for 2 years i got hit buy a guy with no license.. i don't want to scrap it since that would be one less bronco out there. what its the cheapest way to fix this on my own? I know that i will need a new fence which i have and a radiator support that i can get for 150, but what about the axle? shock tower is sideways, wheel is tilted out, and brakes are shot.. so I'm guessing i would need a new tire rod, wheel bearing.. knuckle looks a little messed up.. not sure though. but would it be cheaper to just get a new axle from a junkyard for say 300-400 or get the parts to fix this one, if you see anything else messed up in the axle just let me know. any advice would be great and really don't have money to do extra fixing or pay for someone since I'm in college on a running scholarship and don't have time to have a job. thank you for reading.
Ouch...!
That hurts...!  I'm guessing insurance would "total" it as it would cost more to have it fixed than it's worth.
Doing it yourself...., there's likely more damage there than meets the eye, & what shows in these pics.
BTW., did you have your insurance adjuster look at it..?  I think they're req. to look at the damage &
supply an estimate & I think it's no charge.  Doing so would present you with a list of the damage.
T
T2HUFF
tell me about it, and insurence doesn't cover my vehicle.. just the other persons. however i have guy that is selling me a dana 44 and 9inch rear from a 79 ford for only 300 so i guess ill be having to do a sas which from reading on here doesn't seem to hard and i don't believe i would have to do any mods to pull it off.. i think, anyone feel free to correct me if I'm wrong here. the only odd part to me was how it wouldn't start after (well it started once but ran for 2 seconds then died.) I'm guessing its because the battery cells though since it went flying around inside the engine and a hour after the accident the power locks and windows wouldn't work. any advice anyone can give on what to do i will gladly take. being with the sas and 9inch swap or anything like that. just want to see her on the road again soon.
T
T2HUFF
i guess the main thing I'm asking is if i do the axle swap, new radiator support.. should it be fine..? i know thats a hard question since no one can really look at in person. unless your in grand rapids Michigan in which case ill buy you a case of beer to check it out. but all the photo are the only mechanical things that are wrong, other then that the frame didn't get hurt, engine did hurt or any other main parts.. just axle.
Somebody correct me but isn't you're front end an '86 IFS.., and the '79 D-44  a solid axle...??
The inertia switch may have activated on impact.., shuting off the fuel.., if you have fuel injection
that year.
Some FS Bronco folks will chime in with more info. than I can provide.
T
T2HUFF
it is a 86, but i have heard that a lot of people have done/prefer the solid axle so i guess i will give that a try haha, i was thinking that to but don't know where that is located, i think wanna say under passenger floor bored but not for sure. if anyone also knows anything on that it would be great. and yes i would love for some people to chime in and give suggestions and comments and hopefully i can turn this into a build page soon.
yo T,
Here are some Dana 44 Solid Axles Suspension (SAS) Swaps;
Installation, Dana 44 in an 85
Source: by Tim O (RED WAGON, redwagon) at http://www.supermotors.org/vehicles/registry/detail.php?id=6130&s=33498
Installation, Dana 44 leaf spring from 78 1/2 F150 Supercab in an 85
Source: by Chris B (Blue, bronco boy) at http://chrisb.users.superford.org/Bronco/Projects/SAS/SAS.html
Parts Cost & Sources, Dana 44 from a 78 Bronco in a 92
Source: by Jeremy M (Big '92, jermil01) at http://www.supermotors.net/clubs/superford/vehicles/registry/media/107235
I have many more Links in my archived site @ http://web.archive.org/web/20110704073853/http://www.broncolinks.com/index.php?index=359
Read my Signature below on how to access original URL
T
T2HUFF
thank you very much for those, it does help a lot! 3 question i have which i know are rookie questions but do i need to use 78/79 bronco shock towers or would 80-86 bronco single shock towers work? then do i need to make radius arm brackets or can use the ones i already have? i have seen how many people have dropped them and all that stuff but does it need to be done? this truck is my daily drive and don't off road very ofter. then last question is do i need to weld track bar to my frame or is there anywhere else i can put this?
Does the 79 Ford SAS have Front coils or Leaf spring?
If leaf, no radius arms are needed; see Chris B's Link. ' have not done this; have helped 2 friends, but never was around to see how it finished,
Others here will help I'm sure!
Information & Parts Sources.. EXCELLENT
Source: by ocalabronco at
http://broncozone.com/forums/index.php?showtopic=6595
EXCERPTs:
This is not meant to be the SAS bible, but rather a "cliff's notes" for this swap. First before you even consider engaging in this extensive modification, you need to ask yourself if you really need it. For the everyday, average wheeler, the TTB is fine. a simple investment in a lifetime alignment plan. The TTB has its place, and will hold up to 36" tires with smart driving and proper maintenance. Now, with all that said, I'll get on with the info/writeup.
1/2 TON PARTS
First, you will need to get a hold of a Dana 44 front. most of these came from f-150's and broncos, but some F-250's had leaf sprung axles, refered to Dana 44 Heavy Dutys. these axle had 8 lug outers, with a matching 8 lug D60 out back. for ease and simplicity, find a coil sprung axle, since our broncos are already setup to run coils. For a clean looking swap, you'll need to acquire the upper coil buckets, radius arms (should come with the lower coil retainers), and radius arm brackets. you will more than likely have to fabricate your own track bar bracket at the frame. you CAN re-use the stock track bar, but some prefer to use aftermarket ones or make theirs custom out of DOM tubing. Most people like to use shock mounts from a mid 90's f-250 or 350, because they allow for the use of double eyelet shocks, instead of the crappy stud mount shocks that come factory on our rigs. this opens up a wide possibility of shocks to use.
/4 TON PARTS
most of the above applies here, with the exception that your parts will come from a 78/79 f-250 with the D60 rear. the front comes with leafs that you more than likely will not re-use. refer to the one ton section for info on that.
ONE TON PARTS
This will consist of a leaf sprung D60 front and one of many 1 ton rear ends. if you have a 92 or later, you must use a sterling 10.25 or modify a D60 or D70 to accept a tone ring so the E4OD can read the signals coming from the VSS. for this, you will have to fabricate a front crossmember to mount the front leaf spring hangers or shackles to. some people mount their shackles on the front xmember, others do a shackle reversal at the aft section of the spring. for more in depth information, visit the SAS forum at fullsizebronco.com and read the stickies at the top of the page. this axle will come from any f-350 from 77 to 97, but there are slight differences. the 77-79 60's had a narrower mounting distance than the newer axles, because the frames in the early days were straight, as opposed to later frames that widened at the motor. this isnt to say you can use them, but make your mounts accordingly.
PM me with specific questions and i'll try to answer them. and please, READ THIS FIRST
Most have a lift installed along with the Dana straight axle susp such as
Installation, Dana 44 in a 92
Source: by Jeremy M (Big '92, jermil01) at http://www.supermotors.net/registry/2896/15047
Gonna start my sas tomorrow afternoon and hope to have finished this weekend....
I will take tons of pics and doccument everything
* Basicly 78 d44
* Stock 78 Steering ..Sleeve the drag link if necessary to get the right length for now
* Possibly sleeve Trac Bar ..and build Trac bar bracket on frame of bko
* Stock 78 Radius arms .. utilizing rad arm bracket off bko just relocated
* 2" rancho coils off 78 netting 4" used with stock ttb bucket
* Utilize exsisting coil buckets and shock Mounts on bko
* Rear factory shackle flip
* Rear AAL
I know ppl may flame about sleeving the steering but ive done it in the past and it worked great.. im not going to run it like this forever but for now it'll work for me until i go with dom over knuckle but i wheeled a full width bko2 with steering sleeved for years and it worked flawlessly
Next i hung the 78 Rancho 4" colis from factory buckets and slid axle under..
Bolted on the radius arms with new 7* shims and hung the axle on the springs.
I used 2 ratchet straps to set axle close as i could to square and a little foreward then used a bottle jack to jack up the radius arms
I ended up using the ttb rad arm bracket therefore needed to use the rad bushings off ttb setup there a lil diff then the 78 ones just a note...
Once the radius arms were raised up and the brackets on one just for mock up .. i determined the final location of the mounts
I ended up needing to cut the cab mount a little to get the radius arm bracket to fit this is a picture of passanger side i did the driver just a little different ..
how i determined location was by taking a square and scribing a square line from bottom of frame through centerline of cab mount hole and then using that line as the centerline or top rad arm bracket hole .. the height was determined by centering hole on line and clamping the bracket so that the underframe mounting surface was flush
this is a pic of the passanger sida bracket mounted the bracket covered a little of the cab mount so i ended up taking some plate steel the same thickness as cabmount making a tamplate with bracket and cutting then welding to frame you could just cut more of the mount but i opted to do it this way because i had the material and didnt want to cut anymore of the cab mount out
Here is a pic of driver side with radius arm in the bracket..
Getting the arms in once both brackets were on was the biggest Pita..
basicly i just used the ratchet straps to agian pull housing as far foreward as i could while using the bottle jack to raise arms and a bar to get the arms in one side at a time..and then releasing the straps and jack...
Keep in mind there are probably better methods but im doing this toptally by myself..
Heres pics of the modified stock 78 trac bar mount its setup to weld to bottom of frame just under the front of the ttb coil bucket if you look in next pic i notched the bucket to make it easier to weld in bracket
some pics of the newly braced up trac bar mount
welded 1/4 inch thick steel gussets on a 45 deg angle on each side of the chopped 78 trac arm mount
Plan on using the stock trac bar off the 78 mounted to stock location on axle for now maybe use something else down the road but it worked well on the bronco2 i did a few tears back.. And ill post a pic ot the mount welded to frame
Just an update the axle been in the truck two weeks had a serious death wabble due to trac bar bushings being shot... it was serious i ended up ripping trac bar mount off frame and had to take a tow home.... i ended up replacing the bushings and rewelded a new trac bar mount using same factory style mount to bottom of frame similar to old one allthough i droped it an inch lower.. LOOK AT LAST TWO PICS IN POST 25.... but this time i added two triangle gussets one on each side of mount to frame to help distribute the load..as well as a brace to the engine crossmember.... so far so good second day of shakedown runs and ill try highway driving a little this afternoon....
Just a side note that if retaining the factory ttb buckets and shock mounts you need ttb 6 inch shocks to fun the 4 inch sas the ones for a 4 inch ttb are a little short... i just ging to run this though for now im planning on a shock hoop and some14 -16 inch travel shocks in near future.....
also thought id add i still havent done the rear yet as im making sure i get front taken care of first in totality... but it did net me right at 4.5 inches over the stock ttb setup ill post pics later today
by rollingmenace http://fullsizebronco.com/forum/showthread.php?t=159676
guilhermeknob
