WEll HELLO EVERYONE
BRODY0309
Now that I have asked a couple of newbie questions I figure i can show my rig that I just proudly purchased........ :D /emoticons/[email protected] 2x" width="20" height="20" /> Its a 1995 Bronco EB edition Dark Blue on Tan with Tan interior. IT has 124XXX thousand miles on a 5.8ltr push button 4X4 with lock out hubs. Dana 44 Front and Rear axels with 4:56 gears, 6inch Suspension lift with a 3 inch body lift the bumpers have been relocated so there is no gaps. 15x10 wheels and 38X15.5 TSL's. So far the only performance mod I know of is a K&N filter.... BUT that will soon change -_- /emoticons/[email protected] 2x" width="20" height="20" /> The pictures are not great at all I just snapped them on my way in the house today with my Iphone ill get better ones up soon
OH and the price for my Rig as it sits just purchased one week ago 3000.00 yes sir 3000.00 think I got a pretty ok deal B) I know it needs a good cleaning but there just for you to get an idea
BroncoJoe19
Yes, Welcome to broncozone.
That's definitely a nice looking truck, and It's hard to believe the price!
If I were to get another Broco it would be a '95 or '96. I like the '95's cause it is the last year that one could pull diagnostic codes without the need of a scanner. The E4OD trans is rock solid, and has had all the upgrades they made to it by then.
You may want to check the accuracy of your speedometer against that of a friend's. If it is off because of the tire and rear changes, there is a simple fix for it. If you need it, let us know
joe
Mike G
TN
Joe I have noticed that my speedo is off by about 10%. And I don't know why. But at 70 on my GPS the speedo reads about 76. I haven't done anything to it since I bought it so don't know what has been changed. Well thats a lie, I put a new valve stem on the spare and charged the AC.
What is the simple fix you are talking about.
Thanks in advance.
Mike
BroncoJoe19
Thanks in advance.
Mike
Starting in '92 with the digital odmeter on can adjust the Programmable Speedometer Odometer Module PSOM
IMO this was a great post on another forum, and pertains to
'92-97 F-Series & Broncos.
http://www.fullsizebronco.com/forum/showthread.php?t=55005
The "PSOM" is the (electronic) Programmable Speedometer/Odometer Module, which was used on '92-97 F-Series & Broncos. Some Econolines & Aerostars also used it. Earlier trucks use a cable-driven mechanical speedo/odo, & later ones use an electrically-driven speedo with a motor-driven mechanical odometer; both of which are calibrated by changing the plastic gears in the transfer case tailhousing (or transmission tailhousing on 2WD).
Resetting the PSOM is EASY: it uses the "conversion constant" to calculate the vehicle speed from the sensor frequency. more...
Mike G
TN
Thanks Joe.
I might be getting back to you to put it into English for me. I have seen that you have a talent to simplify things for us slow learners. To late to think to hard.
you are da man!
Mike
Virgil3rd
