B-Co Kid
- Joined
- Oct 14, 2010
- Messages
- 235
- Reaction score
- 8
1987 ford bronco carb'd 351w. When using both power windows simultaneously, the voltage drops just a little bit, and when the windows are all the way down, still holding both down buttons, the voltage reading drops all the way to the left. Is this normal?? If not, what could cause the absolute drop in the voltage gauge with both down buttons depressed?? I recently replaced and checked all major connections ie. Batt + to solenoid, to starter, and batt - to block. Same thing happens. All windows work, front and rear, but are not as fast as I think they should be. Front and rear windows have new motors also. so I can't figure out this problem.
