vibration +mild grumble drumming sound
brit
95 full size Bronco Vibration On and Off road. At various RPMs. Ford's EVA (Electronic Vibration Analysis) finds vibration, initially said "fourth engine order" but it does not follow their diagnosis chart. Trusted mechanic's best GUESS is the need for new exhaust system (Suggestions? Recommendations?)
Rumble/Droning/Vibration at all speeds , it is worse when moving-- BUT vibrates while stationary on lift too.
Broncoholics
Broncoholics
Washington State
Sounds like a motor mount is bad. This will send a vibration through the truck when the bolt is touching the frame instead of rubber.
brit
Hey, thanks for the reply.
The motor mounts are new though.
The vibration did improve when they were installed!
Its just still there---
Brit
Elmomo
