Turn signal problem
tom1985
Have a 1995 ford bronco eddie bauer edition.  yesterday my turn signals appeared to stop working they will occasionally turn on after a few seconds but is not consistant.  brake lights work, hazard lights work, and all lights turn on just issue with turn signals only. any ideas?
Yo Tom,
Inspect:
flasher in-cab fuse block.
FUSE #7
Here is the wiring diagram,
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=46699
Turn Signal Switch, aka Multi-Function Switch (MFS) Failure Causes; "...Mechanical components wear out or electrical connections are faulty; If the switch assembly is not operating properly, turn signals, hazard warning lamps, windshield wipers/washers and the headlamp beam selection may not operate properly. Related Components to Check; The switch itself, the electrical connections to the switch and the connections to each of the affected components (items such as turn signals, wipers, etc.)..." by Ford
Multi-Function Switch (MFS) Cleaning & Internal pics in a 2001 Explorer; Miesk5 NOTE, it is electrically & functionally identical to our Broncosite in 92 through 96; "...Wipe with a rag, hit with contact cleaner and an old toothbrush to clean. Regrease with dielectric grease. Save ~$80 for a new switch that will only last ~4 years..."
Source: by Electrohacker @
https://sites.google.com/site/mfs01explorer/
Multi-Function Switch (MFS) Removal & Installation in 92 through 96 by Kevin L.
https://web.archive.org/web/20070306081430/http://kevin-long.tripod.com/mfswtch.html
Multi-Function Switch (MFS), Hazard, Turn, High & Low Headlight Dimmer, Flash-to-Pass & Brake Light Testing & Wiring Diagram in 92-96; "...the MFS testing is done with connectors disconnected; it's strictly an internal test of the MFS; There is no testing for the WCM - you test the MFS, the wiper & spray motors, and the wiring. If they're good but don't operate, it has to be the WCM by elimination..."
Miesk5 NOTE; Brake Light & Turn, High & Low Headlight Dimmer, Flash-to-Pass & Hazard CKTs are a Feed-Through Circuit in Multi-Function Switch (MFS) @
http://www.supermotors.net/registry/media/225114_1
Clubcar
Portland, Maine
I have a 1995 XLT and lost my blinkers.  It was the blinker relay switch located either on the fuse box or behind the fuse box.  Cheap and easy to fix.
B-Co Kid
Tom, also check the light bulb socket.  Not completely sure about 90+, but usually there are two metal contacts in the bottom of the socket, and over time, the contacts lose their tension.  Remove the bulb, get needle nose pliers, adjust the contacts out, so they will touch the contacts on the bottom of the bulb; also clean off any rust/corrosion from the socket contacts, put a little petro jelly or terminal grease on socket contacts before reinstalling/replacing bulbs.  If your sockets are all the way jacked, you can usually find replacement for cheap at autozone/oreilly's/napa etc.  Hope this helps!  B-Co Kid out!
Staff online
