Tub Removal
Bredin
Beacon, NY
Hey,
I was just wondering how hard it is to lift the tub off the frame. How many things would I have to remove from the firewall etc ?
Might be a good thing to invest in some tall floor jacks and move the Bronco into a garage instead of working on the lawn too lol...
Leadsled
Bullhead City AZ(right on the river!!)
Well there is one bad part about doing something that extensive: If you have to ask then you may be over your head on something like that, but I will help you out though. Some of the things you are gonna have to remove are: Steering, fuel lines, electrical stuff for the charging system and ignition, body ground wires. The steering alone should be a blast! If you have a shop with a tall ceiling, probably the best way to lift the body off of the frame would be to use a come-along with wide straps off of the raftors. Then you could just roll the frame out. If you do decide to get into this have fun and be safe.
drubbz
