bronc-o-bug
- Joined
- Mar 30, 2009
- Messages
- 6
- Reaction score
- 0
I have a 95 Bronco with TTB front axle. Especially when I park it in reverse the front wheels seem dramatically towed in at the top (approx. 1+ inch). If I lift the front on a jack and set it back down they sit straight again. One side is worse than the other.
The truck has only 64k origional miles. A 6 inch lift. The previous owner had 36x13.50 Swampers on it. I think he probably ran them for about 30k miles. They were worn extremely unevenly and the truck desperately needed an alignment.
Since then I have switched to 35" MTRs, and had it alligned.
When I lift the axle on a jack, and wiggle the tire and wheel, it wiggles about 1/2". Looking from behind the ball joints appear to be tight (no movement at all), but you can see the wheel move relative to the brake shield which remains stationary.
I am pretty sure it is not supposed to wiggle at all. The bearings don't make any noise when I am driving, and I just had the axle regeared, and no one brought any bearing problems to my attention.
Has anyone had a similar problem that can shed any light on how I can tighted, and straighten this system up.
Thanks
Thanks
