Red Green Jr
Awhile after buying my bronco and rebuilding the c6, I started to realize that an overdrive is very nice to have when on the freeway. I have looked into upgrading to a transmission with an overdrive and found the AOD. Before i go out and buy one, i just wanted to make sure that it could bolt up to my 351M, the AOD was made in the 80's but the M block was also still used into the 80's (at least, i think it was). Does anyone know if an AOD will bolt up to my 78 351M? and if so, are there any major drawbacks or problems that i might run into? thanks.
