trans problem
89Bronco58
Jersey
88 f250, AOD trans, it was driving fine, hit a mudhole, now it wont shift out of first gear, reverse, park and all that are fine, goes right in and out of gear, just wont shift past first, i already checked the governer, fluid, and kick down cable..anyone ever have this happen before or have any ideas of what i can check?>
89Bronco58
89Bronco58
Jersey
ok this post has been here for days now, 20 ppl viewed it, where are all the "moderators" that are supposed to kno things about broncos..What? noone has ever worked with a trans before? whats the point of this site if noone can help you out unless its something stupid like changing the valve stem caps
The point is to help people with problems that you have come across and solved. I really don't think anyone owes you anything. I really hope you were joking because that was pretty rude. :-& #036;
swampthing
tv cable seems to be fined not out of adjustment i took the governor apart and cleaned it but still feels a little tougher then it should so im picking up another one tomorrow
89Bronco58
89Bronco58
Jersey
i was dead serious for that exact reason above, i CLEARLY said i had already checked the governor and tv cable ,, but someone STILL posted for me to check that, r u serious???? and im sure out of all the ppl on this site SOMEONE can give an opinion on something it might be OTHER than stuff i have CLEARLY already stated i have done!
yamaha man
manassas va
sounds like your clutches in your trans have froxe togather my 65 ford truck did does that when i was coming back from mississippi where i got it at 20 miles away from where i got it the trans would not shit in to third and it keep poping out of gear i came all the way back up to va cause ii had no time to get it reparddown there i got it home in 2nd gear. and sone day when i was taking it to a car show up town it all of a sudden stayed in gear and shifted in to third and i took the trans out a month later and the clutch disks were frozen at one time. so it soulds like time to rebuild the thing
swampthing
its not jumping out of gear just wont shift...fluid is clear and thin as water...im changing it tomorrow and i know the tv cable isnt out of place its in the same place it has been since i bought the truck..and yes i know how to adjust it...im gonna try another governor new fluid screen..if i have to i will get another torque conerter and go further into the trans
Heres a mod to reply to your post . 1st thing no one here and I mean no one here owes you anything #2 no one here and I mean no one here owes you anything #3 no one here and I mean no one here owes you anything #4 If I had seen your rude coments earlier they would have probably been your last post here . #5 If anyone else here had encountered the problem your having Im sure they would have added a comment or maybe they saw how rude you were being and decided to not get involved . #6 being that an AOD shifts completely off that TV cable and its adjutsment is very critical to operation then I would check that first but being that your smart ass already checked that then it just cant be it correct . So if the cable is adjusted correctly , the fluid is full , Then your more than likely in for an expensive repair , Oh and if you have any problems with my comment feel free to PM me or ad a comment here but if you feel the urge to be rude make very sure you go back and read comment 1-2-3 and pay special attention to #4 Good luck with the tranny :D /emoticons/biggrin@2x.png 2x" width="20" height="20" />
Why don't you learn something about your truck and be a contributor to the forum rather than a leach. I saw your rude comment and was one of the ones that decided not to respond to a ***** post like that. Go to a transmission shop.
89Bronco58
89Bronco58
Jersey
the first comment i posted wasnt rude at all, i just got frusterated over everyhting , im sure you all have been in bad moods, doesnt make what i did right, i admit that, i just always come to this site for helop and always get it and thought it would be very fast until someone got back to me, so i apologize to anyone that i offended, i wasnt aiming to do that
whitey
North Hollywood, California
yeah well everyone does have bad moods for sure but, you did it twice not once. i'm not getting involved but you have to use etiquette here just like in real life.
mods are on forums to maintain the flow and function of the boards and keep them clean. the fact that the mods here are knowledgable mechanically is a bonus. there's plenty of sites where they don't have a clue.
89Bronco58
89Bronco58
Jersey
yea i no it wasnt cool, i been comin to this site for a while now and i try and help ppl out as best i can whenever im online, i just was trying to help my friend out and idk got ****** about stuff i guess
swampthing
considering he posted it for me its not his truck to learn anything about..secondly i know everything there is to know about my truck but i dont usually run with AOD's cause IMO they are ******. If you think that him asking for help was a ***** post then you are the *****...some "tech help"
Swampthing, did you read the whole post? Try again right from the beginning. The way you were adding your comments to this post, I was wondering if you were reading a different thread and posting here
eholt80
